Anonymous | I have two of these amps and a 200A alt. i wanna put some subs under the backseat of my ext. cab chevy truck (2003). I know i'm gonna have to use 10's or 12's and they have to be able to be used in about .7 cu ft of air space in a down fire box. What subs should i get to sound good and be pretty loud, but not cost me something unreal!!! Should i get some L7 10's or something??? Oh yea...i dont realy wanna get JL... |
Silver Member Username: HydroPost Number: 102 Registered: 12-2003 | Elemental Designs A-Series 10 inch sub performs great with small enclosures(0.2-0.5cf) and can handle from 650-1300 watts. |
New member Username: VqmanPost Number: 3 Registered: 02-2004 | what kind of music do you listen to? rap/hip hop? go with JL 12W6 rock/pop? go with Diamond M3 10D4 country? ??? -vq |
Silver Member Username: Its_bacon12Post Number: 147 Registered: 12-2003 | i would reccomend e10a.22 subs by Elemental designs, the K series subs... www.edesignaudio.com im not sure how much they are a piece but its not too much but its worth it |
Silver Member Username: Its_bacon12Post Number: 148 Registered: 12-2003 | im sorry, A series subs... they work anywhere from 300-1000 wrms in .5 cubic foot sealed boxes so you should be fine running them at 1 ohm 600w rms each and they fit in super tiny boxes so no prob there either ![]() |
Silver Member Username: Its_bacon12Post Number: 149 Registered: 12-2003 | rofl sorry again, i didnt see hydros post... yea anywez, this would be an awesome sub for your accomidation |
