I thougt I was all set on getting a Type-X to run off of the 1000 w @ 2 ohm rms mrv Alpine amp, but after researching more on the Type X, I was wondering if I really should consider something different. Can you guys think of other subs that would outperform the type x, with no more than 1000 watts rms. One sub that is similar that comes to mind is the RE SX. I wanted to have an all alpine system, but if I'm gonna drop $250-300 on a sub, maybe paying a little extra for something better won't hurt.
I know Glass said that the Eclipse T's are close to Re x.x.x! The only thing is, the Eclipse T is rated at 750 rms, don't know if 1000 watt's would be to much for it! Then of corse there is the usual, Adire Brhama x.x.x can't think of any more subs that can handle that kind of power and stil sound good! Hope that helped.
Yeah, I was kinda thinking about an Eclipse. My friend has an Eclipse Aluminum and it sounds really really really nice. I don't think the MRM M1001 would be quite enough to power the brahma or x.x.x though.
the eclipse t's should be ok with that power. just don't turn the gain all the way up on the amp and you should be alright.
Glass and them say that a brhama only needs around 800 watt's to reach it full excursion. Also look at the 13w7 I have hurd of people puting 1000 watt's to it and they say it really pound's!
Yeah. I'm looking at something with a price relative to the type x though, lol. I could look into a brahma or maybe a x.x.x., but a 13w7 is gonna be way to much. Stupid JL.....
The JL subwoofers are 3 ohm, so the best match with the JL route for the amp you're using would be the 12W7, it's 750W RMS, which your amp will put out at 3 ohms give or take. The 12W7 Will hit very hard, more so than the Type X, and has excellent SQ. The Eclipse Ti will work well off of 1000W RMS, they are underrated. Brahmas won't work as well since it is a dual 2 ohm subwoofer, the X.X.X. would work as long as you got the dual 4 ohm coil option. The Image Dynamics ID Max is an excellent subwoofer as well, don't overlook that one.
Hey Jonathan. How would an Eclipse SW9102 10" TITANIUM compare to the Type X. And if I did go with an Eclipse, I haven't gotten the MRV M1001 amp yet, so I could easily send it back and buy a diff amp. What would you recommend to run an Eclipse Ti?
I have read up on the Atlas, and I think I am gonna try it. Actually, I am definitely gonna try it. It would go perfecty with the amp I have too. I'll tell you guys how it sounds once I sell my current sub and get an Atlas. I might need a little help with the wiring though once I get it. Kinda crazy, I don't even get how the thing works. The second voice coils is smaller to help with different qts applications... what? And where would I get a 1.5 ohm resister? Weird.
