What does inverting the sub do to SQ and SPL?
i was just wondering if you had just say 3 12w7s and 2 were regularly mounted and 1 was inverted what would this do to SQ and SPL?
ThatGuyYouKnow
Inverting just makes more room in the box thats all.
some dont like seeing magnets so they make a box to the specs for SQL or SPL. subs take up room inside the box, mine is .15cuft, if u make ur own box make sure you add yours in or it could turn up to be crap, or sumthing good, what ever your taste is.
