Explain thisone to me...come on try it...
Username: Subfanatic
Walton, Ky Usa
Post Number: 84
ok try this one on for size i put my sub ina a box i built and i turned it on and it broke the baffle in half
Username: Mr_kebo
Albertville, Al USA
Post Number: 128
baffle not strong enough
Walton, Ky Usa
Post Number: 86
its 3/4 mdf and just snapped it in half...owned its life...it was amazingly powerful...it was intense
Username: Mr_kebo
Albertville, Al USA
Post Number: 129
Must be a pretty Stout sub. Should have atleast doubled uo on the front baffle.
Walton, Ky Usa
Post Number: 87
idk its an eclipse ti only a ten...it shouldnt have dont that
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 111
the baffle must be at least 1" thick, mdf. I just build a box for my 15" x.x.x. about a month ago. I used 3/4" mdf and 5/8" mdf boards,glued and screwed them toghether and its amazing!!the rest of the box was 3/4" mdf
Username: Rob_brown
Post Number: 65
DR MAX, would you mind e-mailing me at bertobrown@aol.com or putting those plans up on this? I woudl really appreciate it, i recently ordered a 15" x.x.x and haven't found a box that i like. Thanks. Robbie Brown
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7438
yup for these big subs ya need to double up the front baffle or face of the box and glue it up to support the weight of the sub itself.
these subs can weigh about 50lbs or more a piece.
