I have focal 6.5 components with RMS 100, Max 200, and 6X9 with RMS 75 and max 150. What amp should I get? I have been told Eclipse PA 5422 but I am wondering if it has enough power. Also been told fosgate P8004. I am looking for an amp that will not burn out or blow my speakers with good control and great quality. What do you suggest? Space is not an issue and I have bought a 0 gauge wiring kit
actually, 75 watts is not enough for those focal utopias. They need a good amount of watts, i would recommend about 150 or 125 at least to those. A good amp would be the jl 300.2 for tha focals, and then a cheaper one for tha rear.
