Subsonic Filter on Amplifier
Jameson
I have 2 JL Audio Subwoofers in a ported box and the box is tuned to 34 Hz my amps subsonic filter can be set from 15 Hz to 40 Hz should I set the amps filter the same as the box's tuned frequency?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 124
No. Set it a little lower. Like 25hz.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7092
about half an octave down from the tuned port freq.
25Hz is about right
Username: Alpineblaster
Post Number: 12
how do u know what to set it at becuase i have the same thing and i dont know where to put it i have a sealed box and my subsonic range begins at 10hz
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 177
you do not need subsonic filter with a sealed box.
Username: Glasswolf
Post Number: 7235
you can set the SSF to 20Hz for a sealed box.
that will prevent power from being wasted trying to reproduce any signals below the range of hearing.
Although in actuality most source material is filtered below 20Hz already.. CD is. MP3 is. Radio can't even reach 20Hz. Neither can tapes.
you'd pretty much need a signal generator to go below 20Hz unless it's just harmonics of produced frequencies anyway.
