Kicker L7 or JL 12w6v2
I was wondering which subs should i go with...I was wondering if mtx 1501d amp will run these bad boys.please let me know thanks guys...by the way i want 2 subs
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 341
IMO the JL is a better all around sub. Square subs have stress points that cause them to be very unreliable. I also feel that their sound quality is not on par with the top end round subs.
If I was you I would go with the JL. The W6 V2 is a great sub, and with 2 of them I am sure you will be happy. As for your amp, I beleive it will work just fine. RMS is 1000 watts at 2 ohms, so with 2 w6s it should work just fine.
taylor17
Me too! Go with the Jl
Low Lowz
f*** that, go with the solobaric man, that sub will bang the hell out of your ride
Username: Jmloughrey
Farmington, CT
Post Number: 742
its personal preference, i have 2 solobarics at the moment, the hit pretty hard and are alright sounding if you build the box propery...SQ sub...not by anymeans
