Alpine or adire??
Username: Trev87
Glennville, Georgia Usa
Post Number: 40
i cant make a decision so can anyone tell me what would be better of these 2 subs. two 12" alpine type r's or two 12" adire shivas? oh and im mainly lookin for hard hitting bass becasuse i mostly listen to rap thanks again trevor.
Username: D1slocate
Cary, NC US
Post Number: 35
Don't shivas have an rms of 650?
If they do, you are gonna shell out a lot more money for an amp for those.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 121
650rms thermal, its not a power requirement
Username: Trev87
Post Number: 41
i already have an amp so ill basically be putting 300 watts to each sub so what would be better for me?
madfatchickkiller
Honestly I don't know the specs of the Adire's, but I do know that R's run at 300rms, which is what you have, so I know you wont be dissappointed by the R's, they are good subs
Username: Hdubb
Farmington, Nm Usa
Post Number: 246
the shivas will run great with 300 rms. the only thing is that shivas are dual 8 ohm so you can only wire them to 8 or 4 ohms
Username: Taylor17
Kopperl, Texas
Post Number: 8
Alpine I think would have better spl and the adire has sq
