How do the 10 inch w7's compare to the 12s or 13s?????????????
Username: Aaaavv
Post Number: 7
i know the 13's and 12's hit harder but if you were gonna go with a pair, which sounds better or has better sound quality, between the 3
Username: Jmloughrey
Farmington, CT
Post Number: 724
the 10" would have better SQ over the 12" possibly, its too hard to tell really, depends alot on the install...
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 330
I am a fan of 12s. IMO 12s have a better all around balance. 10s I find to be a little more punchy, and the 13 will slam, though I feel it will fall into the same area I put 15s. As I have stated before I listen to a wide varity of music so I want a sub that has a good over all balance.
