Should I get a new alternator?
eljefe
I have a 94 Totota Pickup and I just got 2 12in Sony Subwoofers. My friend gave me a cheap 2000watt amplifier. Do I need a new alternator or what what other things can I get?
what kind of amp is it
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 256
how bigga alternator u have in der right now?
eljefe
The amp is a cheap amp, its an Audio Mobile MPA-7000 2000watt amp. I dont know how big the alternator is, its the stock one.
Username: Carguy
Post Number: 1346
If it's stock then it'll produce somewhere around 65A - 75A. Since you said it was a cheap amp, it's probably 2000W peak, meaning it can be anywhere between 80W rms - 200W rms. Some manufacturer use a factor of 10! That is pure lie but they actually do it.
eljefe
Yeah its a cheap amp, but I got it for free. So I don't need a new alternator? Anyways I dont think I am going to install the amp in my truck. But if I did would I need a new alternator with 2 12inch subs and 2000watt amp?
Username: Mikey
Miami, Fl Puerto Rico
What's the highest alternator amp range I can get for my maxima 95 - 98? Anyone???
Username: James1115
Wilton, Ct
Post Number: 489
if it were true 2000 watts yes you would but being a cheapo I doubt it you should be alright. As far as the maxima ? goes you can get whatever you want depends on how much cash you got.
