$1000
I am wanting to get 4 12" subs and an amp. I currently have 1000 dollars saved. Im looking for a good mix of SQ and SPL. Whatever subs i get will be put in a sealed box since i listen to alot of rock and rap
Username: Joe718
Brooklyn, NY
Post Number: 286
You should check out the kicker comp vr sub, and the rockford fosgate 1000bd amplifier. Just if you get the 4 ohm coil version you will be straight. What car are you fitting these into. The box is going to be really big for 4 subs.
Username: Jmloughrey
Farmington, CT
Post Number: 513
why dont you just get 2 high quality 12's like some eclipse Ti's and a good quality amp instead of mediocore product you dont need...
