What watt sub?
trev87
i just bought a 1200 watt amp and im looking to buy one subwoofer if i get a 1200 watt subwoofer will my amp be ok or will it blowup?
Username: Jmloughrey
Farmington, CT
Post Number: 492
well...what amp did you get, we need to know what wiring options are available to us...
trev87
i got a legacy 1200 watt 2 channel bridgeable MOSFET amp it has 2 ohm stereo stable and it is bridgeable into 4 ohm i dont know anything about amps and there wiring so if what ive told you here doesnt help let me know.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6286
ok that amp isn't really 1200 watts. It's probably closer to maybe 100 watts x 2.
do you have a model number so we can look up the actual specs?
trev87
where would i find the model number at i ordered it from a magazine and it isnt here yet it should here soon though
Username: James1115
Ct
Post Number: 11
dude you should have asked a few questions about that amp before you went and ordered it! We prob would have steered you away from that choice.
trev87
this is what i know about it:
2-channel Bridgeable MOSFET
1200 watts (600x2,1200x1 bridged)
specs:
frequency response: 10hz-30 khz
S/N ratio:>90 db
THD:>0.04%
i have seen this amplifier on www.woofersetc.com and the product number is LA790 if that would help it may have more info on it if you want to look on there
