Need HELP NOW!!!
Username: Symplestiles
Stockton, CA Usa
Post Number: 250
im installing as we speak. on the amp install kit from knuconceptz (4guage one) what is the clear blue thingy? the plastic peice? it says One InLine Fuse Holder w/ 80A fuse but where does it go? its this under the hood where the power conects to the positive batt. terminal? HELP PLEASE!!!
Username: Boopers
Lima, Ohio United states
Post Number: 272
yes, that is the part that goes within 6 inches of the battery connection
Stockton, CA Usa
Post Number: 251
thanks thats what i thought. thanks you!
