, im just wondering if visonik subs are any good at all and if there worth getting , and i also have another qustion, if you have 2 , 1200 subs , wat would be the best way to power them and wat kinda amp would i need. i ether wana get 2 12 visonik subs and a 15, or 2 12inch type Rs, i need some advice on subs and wat would the best way to power them
Help2
Visonik is not a good make. and you dont want to mix subs...eg 2 12"s and a 15" For the 2 Type Rs, a JBL 600.1 would work nicely. If youre just out looking for a deal... You get what you pay for normally. just remember that
