Like
Amp for shiva
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729085228 &tc=photo
OR
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729083833 &tc=photo
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5427
for a single Shiva? that KX600.1 is plenty
the e1400 is overkill.
Thanks for reply glass!
Why is it overkill? It's Rated Power:
240 W RMS x 1 @ 4 ohm (12.5V);
I found few other:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729235351 &tc=photo
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729467911 &tc=photo
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729235113 &tc=photo
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729467948 &tc=photo
I'm thinking memphis would be right but i'd like to see your opinion
Username: Glasswolf
Post Number: 5437
oh yeah I was thinking of another amp. I just saw the header for the amp model, because on dialup it takes forever to keep loading ebay pages.
anyway for a shiva anything up to 650 watts x 1 @ 4 ohms is fine for that sub.
1200w x 1 @ 2 ohms if ya want to run a pair of them
they don't need that much but they'll take it.
minimum I'd go 300 watts each for them
memphis amps are good. so are the kicker and JL ones you listed.
any of the bunch should be a good choice.
Facebook
Directory
