Like
Jl audio vs infinity kappa perfect vs alpine type x vs memphis
Username: Illuminati
hey guys i am just starting to buy a sound system for my 2004 lancer
i need some help on subs thou i dont know what i need and how many
i listen to rap and hip hop
my question is what sub, what size and how many do should i get
i am looking at the infinity kappa perfect subs
jl audio 10w7 or 12w7
alpine type x sub
or a memphis sub
any help and opinions would be appreciated
thanks alot
stav
Username: Erik123456
Arlington, Tx
Post Number: 173
jl is gonna be like 500 bucks more than the perfects
you can get 10" perfects for like 80 bucks
what would sound the best thou i rather take my time and save up but do it right right away
i was also thinking about the 6wv2 series i believe from jl the model under the w7
Arlington, Tx
Post Number: 174
if i were u id get a cheap but decent amp like the bp1200.1 and get 1 12" RE XX.X like glass was talking about
that will be loud enough for you and you will save some $
just get the biggest ported box you can in the trunk
big d
People at tweeter might tell you JL is the best yadda yadda yadda. Infinity Kappa Perfect are just about $400 less than the JL's. Honestly, The JL W7 is a better sub but it ain't worth $400 dollars more. Don't worry at all about the perfect hittin hard cause they DO!
Facebook
Shop Related Deals
Directory
