I need help choosing my amp!!!!!! plis
Username: Chary
Dominicab Republic, Santo Domingo
Post Number: 23
i want to know what amp i need for my pair of vmax 12", i dont want the amp very expensive, more or less like 200 dollars. what you recommend.
Username: Audiobahn_man
Freakmont, MI
Post Number: 154
jbl 600.1 find it on ebay
Username: Fishy
Tamarac, FL USA
Post Number: 374
Which ones do you have? The svc(single voice coil) or the dvc(dual voice coil)?
These guys would work for either.
Used -
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5724507454 %26
New -
http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=453
If you have the SVC model I'd consider this new, discontinued Xtant a "Best Buy"
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5723596530 %26
Get back to me with which model you have and mebbe I can find more.
-Fishy
Username: Chary
Post Number: 24
But can i put an amp of one channel with a pair of v-max. I have TWO Vmax not one. i wanted to buy an amp to move the speakers and deck of the interior, i suppose i have two buy two amps. What do you recommend me.
Username: Jonathan_f
GA USA
Post Number: 2112
You don't have to buy two of them. You wire both subs to the same amplifier. What this does is creates a different impedance (resistance). If you wire two speakers in parallel (both speakers connected to the same amp terminal) you cut the resistance in half because the current has more paths to flow, similar to if you used a y fitting on a water hose, past that point the water wouldn't have as much holding it back. You'll get 600 watts total at either a 1 or 2 ohm load with that amp, which will work with the Vegas, whether their SVC or DVC.
Username: Cleveland
Post Number: 8
alpine mrd-m501
it a true digital amp ?
581 wrms
990 wats max
