I have a 1998 corvette c5 and am just about to put in a stereo. I can easily fit a single 10.... I would consider using 2 though.. I wont have a ton of airspace for the boxes if I do 2 though.. Its a pretty small cab as you can imagine.. Im more of a rock person, the occasional rap.... Should I do 1 or 2?? AND What do you think the CLEANEST sub would be? I will build the box to specs... Thank you Roy
