Paradigm, Boston Acoustic, B&W...need advise for surround spkrs
Username: Hooterville
I have Onkyo AV receiver and need pair of surround spkrs. Mostly for DVDs and sometimes jazz & other music. A speaker repair tech guy recommended: Paradigm Atom, or Boston Acoustics ??, or B& W ?? (something comparable to the Atom.) My front spkrs. are large Advent spkrs.(10" woofer & crossover tweeter) that I bought in 1975. I don't use a subwoofer.
I have heard the Paradigm Atom & Mini Monitor, but I'm not familiar with either the Boston Acoustic or the B&W spkrs. Suggestions please???
Username: Magfan
Post Number: 1603
Are you willing to replace the Advents?
The HT guys say it's best when the speakers 'match' in tone and presentation.
You may end up with a sub, too, but that's less certain.
No choice but to keep the Advents. They not only deliver awesome sound, they also provide my deep bass. I'll be mounting the rear/side speakers on the wall behind me, about 24" above my head. No choice there either. It's a small room.
So I need suggestions: Paradigm Atom or Boston Acoustic ??? or B&W ??? The Atom has a 5 1/2" driver and a 1" tweeter (highly praised.)
Suggestions?
Username: Artk
Albany, Oregon USA
Post Number: 13211
Among the three you have listed the Atoms would be your best bet. They are easier on the amp than the B&W's and would blend better than the Boston's.
Username: Artk
Albany, Oregon USA
Post Number: 13212
For less money consider the Wharfedale 9.0. Don't remove the grilles as you will certainly break a pin as I (and countless others) did.
http://www.tsto.com/Wharfedale_Diamond_9_0_Bookshelf_Speakers_p/2829.htm
