Is it possible to connect any receiver or amplifier to a Pc?
Username: Katmai
Post Number: 17
Username: Nuck
Post Number: 14152
For what?
Username: Katmai
Post Number: 18
For bridging speakers and Pc.For connecting speakers and a pc to each other,there should be a receiver/amplifier in between I think.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 3426
I use an integrated amp from my computer in the office. You can use the line out from you soundcard to a RCA splitter then feeding it to the AUX input of receiver or amp. An even better idea is to bypass the soundcard completely and use one of the many cheap USB DACs (digital to analog converter) out there.
Username: Chitown
Post Number: 1458
Some of the newer sound cards have optical Toslink output that you can connect to your receiver.
Username: Katmai
Post Number: 21
Thanks for your answers.
David,what if there is no Aux on the receiver?
Stof,I think my sound card doesn't have it.
Username: Dmitchell
Post Number: 3432
Use the CD input.
Username: Mike3
Wylie, Tx USA
Post Number: 2257
You can also use a mini-RCA to RCA Conversion lug out of your line out of your sound card. Make sure it is a stereo plug, they look like this;
http://www.audioadvisor.com/prodinfo.asp?number=AQMINI
