New member Username: Dabigrippa
Post Number: 1 Registered: Jun-08
Posted on how can i connect a luxman R-114 receiver to a luxman M-113 amp and utilize the power of both to run two sets of speakers. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 12718 Registered: May-04
Posted on . You'll need "pre out" jacks on the receiver. Do they exist? |
Post Number: 2 Registered: Jun-08
Posted on yes but then the main speakers on the rcvr don't work when i hook the amp to the pre outs. |
Post Number: 3 Registered: Jun-08
Posted on what about Y connectors on the pre out main in? |
Dallas,
TX
Post Number: 12719 Registered: May-04
Posted on . They would probably solve the problem. Give them a try. |
Post Number: 4 Registered: Jun-08
Posted on i do know what i'm doing. thanks for your support. |
