When is more power warranted?
Username: Vulture99
Post Number: 23
I have little sense or experience with separates and a large appetite for power. I currently own a NAD T763 and run it in 2 channel mode with PSB 5Ts. I'll soon be adding a sub, two surrounds, and a center channel.
My question is, at what point does it make sense to add power to my system? I mean, the T763 puts out a lot of power on its own, but Saturday Audio has an attractive price on the C270 amp. Would it make sense to add this to the T763, or am I just looney?
Thanks.
J. Vigne
This subject has been covered here quite a bit in the past. Do some research on past treads and if you just can't find your answer come back and you'll get an answer. Please look first.
Username: John_a
Post Number: 1261
Mike,
C270: "120W x 2 Continuous Power (8 ohms)".
T763: "Power Output: Stereo Mode (8 ohms within rated distortion): 2 X 130W"
and...
"Simultaneous power output surround mode: 6 x 100W".
Seems just two of the T763 channels are essentially equal to the C270 even when its other four channels are also delivering at 100 W.
