Car speakers for home use?
Username: Gurpreet
Post Number: 8
Its a thought... I have a Denon stack system... which is 2x30w RMS into 4 ohms... anyhow... the speakers I have are from an old Technics mini system and they are 100w @ 6 ohms 89db...
So I was experimenting.. and I put on a 5 1/2" component... Infinity Reference 5010cs... and it sounded really good... its rated 90w RMS max at 4 ohms and is sensitive to 92db I think... but it'd sound better with the cross over I bet...
Good idea or bad idea?
The design seems the same in the form of connections etc and basket structure.
Username: Gamerdude
Ontario Canada
Post Number: 420
The amp is 4ohms
Same with the speakers
they match works fine
Username: Project6
Post Number: 13129
It is an idea. Whether it is good or bad depends on how you define what.
Username: Jan_b_vigne
Dallas, TX
Post Number: 9875
Define "what" or define what?
Username: Project6
Post Number: 13135
Yes
