Low humming noice when cd player is pluck in
Username: Sharkfin
av receiver is pioneer Asx 2
dvd player pioneer 380
connection dvd to Av receiver via coxial cable
my Tv is connected to DVD via the digital yello cable
the minue i pluck in my CD player .. CEC 3300
there is a low humming noice when no signal coming thru when i turn on receiver to listen to cd ... any suggestion
Username: Jan_b_vigne
Dallas, TX
Post Number: 9237
You have a ground loop. You have to find where it exists and alleviate the situation. Put "ground loop" and "solving ground loops" into a search engine and read a few of the entries. This should give you a basis for finding the problem.
Username: Sharkfin
thanks alot .. , previously the entire system is connected to one power source .. recently , i pluck my dvd player to a differnt power source
that could be the problem for the ground loop
i dont understand what it really mean reading the article , but roughly the problem could be cause by the differ power souce i use .. will try tonite
.. cross my finger
