Assuming you do not create some sort of weird load with the second set of speakers the amplifier should be OK. If it gets unusually warm, you should lower the volume and possibly disconnect the additional speakers.
Well, the amp gets warm with just one pair at high volume so I was thinkign an extra set would mean i can set the volume lower and thus reduce the amp from heating up?
