tristan Unregistered guest | if got 2 300W 10" subs and a 400W amp, would it be better to do series or parallel wiring |
Bronze Member Username: Bmw325isPost Number: 12 Registered: Sep-05 | I would say parallel since in a series i would think 300 watts of the amps would go to the first sub and only 100 to the second but i am not positive on this. |
Gold Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 1436 Registered: Feb-04 | Car forum please. And Kevin is unfortunately wrong about how electrical load works. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5902 Registered: May-04 | kb - Here's a start on understanding what happens. http://www.bcae1.com/spkrmlti.htm |
New member Username: DubkingVancouver, BC Canada Post Number: 3 Registered: Oct-05 | single four ohm, series parellel as long as the amp is 2 ohm stable |
Unregistered guest | hi i have 2 12 DUAL VOICE COIL SUB 1200W 12" subwoofer 4 Ohm Impedance 2.5" Dual Voice Coil 60+60 Oz. Magnet 1200 Watt Rated Power AND 1 lenzer VIBE 261 2400 Watt 2 Channel MOSFET Amplifier 1200 WATTS X 2 STEREO 2400 WATTS X 1 MONO 2 OHM STABLE, TRI-MODE CAPABLE BUILT IN HIGH & LOW CROSSOVERS VARIABLE BASS BOOST REMOTE SUBWOOFER CONTROL i how do i connect subwoofers to that 2 chanel amp to get best quality bass |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 5977 Registered: May-04 | Go to the car audio section of the forum. |
