Speakers for Small Bedroom??
Mc X iT
hi, i am looking to update my speakers in my bedroom, which measures about 4m x 6m. I currently am using a LXI 150w/c power amp w/ Nad pre-amp. I listen to strictly hip hop, and from time to time enjoy LOUD music. I dont no whether i should look for floor speakers or book shelfs, and i do not want to have to buy a subwoofer. Any suggestions?
thanks.
Username: Edster922
Post Number: 936
It'd be hard to find a bookshelf that could match the bass extension of floorstanders, but you could do much worse than these:
http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASB2
These floorstanders would go 15Hz lower though:
http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASF2%2E2&product_name =F2%2E2%20Speakers%20Black,%20Pair
charlesw
Mc,
Athena AS-B2 will fullfill your needs.
I have a pair of these bookshelf in my small room 4m x 7m. I use this for my front speakers with the Yamaha av receiver for stereo hi-fi music listening.
It has a power of real bass impact.
No need to buy a sub.
It produces loud, clear, and accurate sounds when I listen the jazz, blue, rock etc.
Athena floorstanders have more power but I have no space for them in my small bedroom.
So I bought the AS-B2 bookshelf speakers and enjoy it very much.
charlesw
Username: Edster922
Post Number: 944
BTW, those B2s are going for $100 off their regular price which was $250.
