1000W sub to 450W amp
Username: Bass_buster_bob
Post Number: 7
will a 1000 watt sub work to hook it into a 450 watt amplifier? would I get all the sound quality out of it that I could?
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 82
What type of amp and subs are they, and what is the rms rating of the amp?
Post Number: 8
My amp is an MTX Road thunder (RT404) heres soem of the the specifications
Power output: 37.5 watts RMS x 4 (4 ohm load), 75 watts RMS x 4 (2 ohm load), 150 watts RMS x 2 (bridged mono, 4 ohm load)
Frequency response: 20 Hz-20 kHz
THD: Less than 1%
Signal to noise ratio: Greater than 100 dB
Dimensions: 9.75" W x 2.1" H x 11.5" L
Regulated PWM Mosfet power supply
Defeatable 85 Hz 18dB crossover, selectable for low pass/high pass operation
Smart-Engage auto turn-on/turn off for easy integration to head units
Real-time computerized protection circuitry
2 ohm stereo stable.
I thought it was round 450 watts is what it said on the box.
the sub i was looking at is a 1000 watt JVC 12" woofer. i dont know much about that brand but the price is pretty good ($76.50) so i was thinkin of getting it, cause all i got are a couple "thump" 8 inch woofers whic were only 40 bucks for the pair, enclosures n everything. so theyre not the best quality. they distort abit quite easily whenever heavier bass is used. so yah. lemme know what ya think. thanks
Username: Jonez788
Post Number: 107
Uhhhh, not a good idea.
Good system with bass=$$$$$$
cheap system w/o bass = waste $$$$$$$$$$
Any upgrade for your car system would sound better than stock, but once you haer a good system you would really know what's the differernce.
