Slot ports
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 70
If I convert the round port diameter to slot port area do i keep the same length?
Can someone give me an answer?
Post Number: 73
my sub calls for a 4"x8" round port, I know that the area of the opening hsa to be 12.57sq in.
But do I still make the slot port 8" long? or does it have to be converted too?
Post Number: 75
someone please help me!
Username: Boopers
Lima, Ohio United states
Post Number: 64
the port surface area has to be the same, what you need to do is calculate the surface area of the round port and make a slot port with equal amount of surface area
Username: Jmloughrey
Farmington, CT
Post Number: 271
http://www.carstereo.com/help2/Articles.cfm?id=31
Post Number: 83
so the length would stay the same?
Username: Caraudiofng
Houston, TX
Post Number: 248
If it's 8" long as a round port, needs to be 8" long as a slot port.
Post Number: 96
thx
Username: Insearchofbass
Post Number: 405
thats if the surface area is the same but if its more the slot port will need to be longer
Post Number: 98
ok, the slot port should be 12.57 sq.in. and 8 in. long.
my box is going to 28x14 3/4x14 3/4.
what ratio should I use for the H and W of the port?
try to keep the vent wider than 1.5"...that way you have less chance of noise.
but if that my calculations are correct then your bow is bout 3 cuft, right?
if so you may wanna think about a larger area port, you would have to recalculate the port length though, but it may sound better.
Post Number: 105
Its 2.5 cuft.
I was thinking of going about 2" wide on the port, but i wanted the port to go all the way across the box,14-3/4" not 28". but i guess that i cant.
