Kicker or adire
Username: Ctx
Post Number: 17
ive narrowed it down to 2 subwoofers the 15in kicker comp or the 15 in adire tempest,I will get 2 of them, what will give me the best spl/sq on a jbl 1200.1 in a vented box, I was worried about the high ohm impedences on the adire because my amp runs best at 1 ohm
Username: Sploosh56
Post Number: 323
i would go with 2 15" Kicker CompVr's. I like the Adire Tempest but I'm a Kicker fan. The Kicker will give you more SPL and sounds pretty good but the Tempest sounds better but not as loud. Go with the Kicker's.
Username: Ctx
Post Number: 18
the only problem i have with the kickers is that they will be overpowered
Username: Jonathan_f
GA USA
Post Number: 954
The JBL 1200.1 is better at 2 ohm than 1. It puts out 1200.1 at either 2 or 1 ohm, with 2 ohm you get less heat and less distortion.
GA USA
Post Number: 955
And actually, the tempest would hit harder, it has a good bit more excursion than a Comp VR. Both will be overpowered, in a vented box I wouldn't give either over 300W per sub.
Username: Ctx
Post Number: 19
the tempest is rated at 750 rms? a subsonic filter perhaps?
Username: Ctx
Post Number: 20
keep in mind i will get 2 of them
Username: Ctx
Post Number: 21
well since everything is overpowered i just need 2 15's that match up and will blow ppl's heads off
Username: Sploosh56
Post Number: 328
2 15" Adire Brahma's :-) If you wanna get kickers get 2 15" L7. Put them in vented boxes.
