Incriminator Audio?
Username: Jones82joshua
Yankton, SD USA
Post Number: 121
Does anyone on here have any experience with IA, most notably Lethal Injection and Death Row series in the 12" Variety?
Username: Fritz1
Pierce, ID
Post Number: 12
Awesome subs!!!!!
Yankton, SD USA
Post Number: 122
I'm currently running 2 Type R 12s off ~1400 watts rms, and my biggest question is if two Death Row subs would still be a step up over the Lethal Injections on that power.
Eventually I plan on stepping up to 2000+ watts, just not immediately.
Username: Fritz1
Pierce, ID
Post Number: 13
The Leathal Injections will easily handle 2000 watts if that is splitt between two subs, running 1000 watts RMS to each is no problem for the Leathal Injection. They will be getting a good workout at that wattage, the Death Row subs will handle alot more than the 2000 RMS. Incriminator Audio seriously under rates there subs power handleing ability. Another good feature that I like with IA subs are they are hand made right here in the U.S.A.
Yankton, SD USA
Post Number: 123
Thanks for your time, sorry I didn't reply sooner. I ended up ordering two 12" D4 Lethal injections. I'll try to put up a comparison/review when they get settled into their new home
