Bronze Member Username: DisturbedpriestPost Number: 14 Registered: Jun-04 | Alright scrap the car idea, i just wanna put one 10" tdx in my truck its a single cab f100 from 1978, But i am putting in bucket seats instead of the solid bench and want to put the one 10 in between the two seats and dynamat the whole truck cuz its so old it rattles.. and I have a mtx thunder 1501d amp is that good enough to push one 4 ohm 10 or should i get the 2 ohm so it is pushing 1000 watts rms??? and the box is ported.. what will this sound like? Oh and will this pound or should i put something else in? i mean i dont have much room with the single cab bench seat right now.. but other than putting a cut through in i am up for any new ideas.. thanks in advance... |
Silver Member Username: Its_bacon12Hfl, Ny Usa Post Number: 896 Registered: Dec-03 | 4 ohm is fine, that amp puts 750w rms at 4 ohm and 1500w rms at 2 ohm, and is probably underrated...its a masive amp and be careful with it it should sound good and pound at the same time |
Silver Member Username: Davids2004Houston, TX USA Post Number: 424 Registered: Jun-04 | Go with one S12L7 DVC 2 ohm and run the amp at 4 ohms. That would be a perfect match. Here is how you would wire it up. http://www.rockfordfosgate.com/rftech/wiringwizard/1_2ohmDVC_4ohm.gif |
Bronze Member Username: DisturbedpriestPost Number: 15 Registered: Jun-04 | Okay, so you think the speaker will rock? |
Silver Member Username: Its_bacon12Hfl, Ny Usa Post Number: 904 Registered: Dec-03 | do we think the l7 would rock or ur tdx? i think both would, but the L7 moreso |
Silver Member Username: Davids2004Houston, TX USA Post Number: 426 Registered: Jun-04 | If you can port the L7 and that bad boy will slam. I had one S10L7 ported with a bd500 and that thing was pretty loud. |
Silver Member Username: Its_bacon12Hfl, Ny Usa Post Number: 909 Registered: Dec-03 | well yea but the TDX series are amazing subs davids, run for about $400 for the 10 inch amazing SQ, amazing SPL i think thats the 10" sub diamond audio hit 169 dB with one 10" sub hit 169 dB....extremely impressive |
Bronze Member Username: DisturbedpriestPost Number: 16 Registered: Jun-04 | I love diamond audio and i have the money to get it.. but i wanted to know if it would pound in a single cab truck bu tits pretty big...?? |
Silver Member Username: Davids2004Houston, TX USA Post Number: 429 Registered: Jun-04 | disturb3d_pri3st Also your title is a little blunt. Sometimes people may not have the answer so they would rather not answer then give you a wrong answer. Sometimes you gotta wait. |
Bronze Member Username: DisturbedpriestPost Number: 17 Registered: Jun-04 | Yeah, i guess patience is a virtue... *laughs* Blah, I am getting the speaker tomorrow, gotta hold off on installing it until i get the bucket seats put in.. i will let you know how well the diamond audio did... probably in about a week keep an eye out for my post, oh and thanks for the info, and next time i will be more patient. |
