New Speakers.
Username: Noob101
Taylorsville, Utah USA
Post Number: 204
Hi i'm looking to buy some new component speakers for my 03 mustang I don't really have a price limit (nothing ridiculous though) but if someone here could give me a few options that would complement my 12" fi Q that would be great. Thanks.
EDIT:
Also something that would run off my Kicker zx 250.2
85 watts x2 at 4 ohms
125 watts x2 at 2 ohms
Username: Noob101
Post Number: 205
http://www.sonicelectronix.com/item_8826_Alpine-SPR-13S.html
Any feedback on these? better options?
Username: Noob101
Post Number: 207
Feedback on these? Better options?
(sorry for the double post)
Username: Livin_loud
MW2 Addict
Post Number: 3328
well the Q is a great sounding sub so it would only be right to compliment it with a great sounding set of components. if you don't mind spending a little more any of these would be fine choices:
http://www.woofersetc.com/p5833/CL51A--CDT-Audio-Classic-525"-2Way-Componen t-Speakers.htm
http://www.woofersetc.com/p7320/FD5000--ARC-Audio-525"-Component-Set-with-S ilk-Tweeters.htm
http://www.woofersetc.com/p3079/CLE51NEO--CDT-Audio-2way-525"-Slim-NEODYMIU M-Speaker-System.htm
http://www.woofersetc.com/p3943/CXS52--Image-Dynamics-525"-2-Way-Component- System.htm
that was with just some quick searching. a definitive max price would help. also, the image dynamics set is 2ohm which will get more potential from your amp.
Username: Noob101
Post Number: 208
Thanks Eric. i haven't ever really heard of CDT or ARC. do you think they would out preform the Alpine i found?
http://www.crutchfield.com/s_500SPR17S/Alpine-SPR-17S.html
Username: Noob101
Post Number: 209
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4928
How about those?
anyone know anything about those? i remember hearing the XXX sub's were really nice how about their component speakers?
Username: Chevyfan502
AQ HDC315AQ 2200
Post Number: 177
I currently have cdt cl-52's and have cdt es's waiting to be installed. the CL's are entry level but will absolutely kill the alpine IMO. Never heard the ARC's but if it was me i would DEFINITELY buy the ARC's over the alpines as well. Not an alpine hater either, very impressed with the type r sub for the $, as well as their 4 channels for the money (I've owned a mrp300-i think was the name, and have a buddy with the arrr's)
Username: Noob101
Post Number: 210
Thanks trevor, I guess i'll be avoiding the alpine's then. So I've decided on a price range of under $300 (but willing to pay more if need be.)
Would like to hear more on the CDT's before i buy one. Also would like to hear if anyone knows about the RE XXX speakers.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11646
CDT ES line is great, you are gonna like those... it's what i run
Username: Noob101
Post Number: 211
M.S. What specific model do you have. thoughts on the sound? bass? highs?
Also, anyone know the difference between the CDT lines? like the CL, EF, ES? etc.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16818
http://cgi.ebay.com/DLS-REFERENCE-R6A-6-5-2-Way-CAR-COMPONENT-SPEAKERS-R6-/170580012758?pt=Car_Speakers&hash=item27b75c6ed6
Username: Rovin
Post Number: 16819
http://cgi.ebay.com/MAXIMO-6-5-MOREL-6-5-2-WAY-PRO-CAR-COMPONENT-SPEAKERS-/120613698127?pt=Car_Speakers&hash=item1c1522fa4f
Username: Rovin
Post Number: 16820
http://cgi.ebay.com/MOREL-TEMPO-6X-NEW-6-5-TWO-WAY-COMPONENT-SPEAKER-SET-6-/130417014833?pt=Car_Speakers&hash=item1e5d75b831
Username: Noob101
Post Number: 212
none of the ebay links worked...
Username: Insearchofbass
Post Number: 16234
http://http://cgi.ebay.com/MAXIMO-6-5-MOREL-6-5-2-WAY-PRO-CAR-COMPONENT-SPEAKERS -/120613698127?pt=Car_Speakers&hash=item1c1522fa4f
http://cgi.ebay.com/MOREL-TEMPO-6X-NEW-6-5-TWO-WAY-COMPONENT-SPEAKER-SET-6-/1304 17014833?pt=Car_Speakers&hash=item1e5d75b831
Post Number: 16235
doesnt work
Post Number: 16236
http://cgi.ebay.com/DLS-REFERENCE-R6A-6-5-2-Way-CAR-COMPONENT-SPEAKERS-R6 -/17058 0012758?pt=Car_Speakers&hash=item27b75c6ed6
Post Number: 16237
oh well still doesnt work
Username: Rovin
Post Number: 16824
didnt realise the links dont work but im sure u can figure out what i was posting & search it back on ebay ...
Post Number: 16251
dls r6
Post Number: 16252
morel maximo 6.5
Post Number: 16253
MOREL-TEMPO-6X
Username: Mmaudioconcepts
KY USA
Post Number: 717
i friend of mine had RE xxx comps and a customer of mine had some Fusion entry level comps and the guy with the REs was soo pissed that he spent so much and didnt sound as good as the entry level fusions. I think REs products today are overrated.
Post Number: 16254
x2
Username: Noob101
Post Number: 213
Thanks for the info on the XXX's. So i have a lot of suggestions ha could someone pick one that they believe would have the best sound. (good mid bass and highs) preferably under $300
KY USA
Post Number: 718
A lot of times midbass is going to be install dependent. If you deaden the doors and possibly make the door air tight or build kind of an enclosure for the midbass driver the response. Sean, Rovin, and MS i know for a fact make good suggestions you can just about pick anything they say if its in the price range. but there are other good brands to look into that might be a little less expensive n some cases.
Atomic
Diamond Audio
Image Dynamics
Post Number: 16312
if you want crisp highs with very good midbass the cdt's are it
x2
Moderator
Username: Admin
Post Number: 9094
All ebay links in this thread have been fixed.
If you cut-and-paste a link from ebay using the "link" icon above, it should work. It seemed like you tried that method, but somehow an extra space (sometimes replaced as %20) was getting added to the url, which caused it to break.
Post Number: 16314
thanks admin
Username: Nd4spd18
Philadelphia, PA
Post Number: 11649
I have ES-5 mids, DRT-25 tweeters (not sure if they use those anymore) and i forget what crossovers.
Highs are smooth and clear on any music. Mids are good also... although most decent speakers will all do good in the midrange... not a lot of variance there. In the tweeters is where you will hear better component speakers mostly.
Bass... from components? Ya know they have these things called woofers for that lol
Reason I say that is midranges should not be used for bass, it's very hard on them, even if they are capable of it. Even with a crossover at ~100hz you can still blow mids by pumping too much midbass through them... you really have to try but it can happen.
KY USA
Post Number: 719
i did mean mid range my bad lol
Username: Noob101
Post Number: 214
M.S. Thanks i think i'm going to go with the ES-520
http://www.woofersetc.com/p1107/ES520--CDT-Audio-EuroSport-525"-2Way-Compon ent-Speakers.htm
BUT, i can't find anything on it's independence. Anyone know if it will run at 2ohms? I'd like to get it but not if i'd be under-powering it by a good 50 watts.. :/
Also, M.S. Ha i was referring to a good mid-bass not deep bass from my sub but something that could give me a more complete sound.
Thanks a lot for the help so far guys.
Username: Noob101
Post Number: 215
scratch that would prefer a 6.5" driver..
http://www.woofersetc.com/p5091/ES610--CDT-Audio-EuroSport-65"-2-Way-Compon ent-Speakers.htm
http://www.woofersetc.com/p9108/ES610X--CDT-Audio-EuroSport-65"-2-Way-Compo nent-Speakers.htm
Again anyone have any idea on independce?
Also anyone know the difference why one is es610 and the other is es610X??
What about Infinity kappa Perfect 6.1? opinion on thoose?
Username: Noob101
Post Number: 216
So after hours of looking... i've come to this...
http://www.woofersetc.com/p9365/CL61A225-PRO--CDT-Audio-Classic-2Ohm-65"-2W ay-Component-Speakers.htm
Or the Infinity Kappa Perfects 6.1
Please help me choose so i can just start setting them up (:.
(ended up choosing those CDT's because givin my amp it's the only one i felt wouldn't be under powering it's recommended rms by a large margin.. but is the CS series significantly worse than es? if someone else has a CDT speaker that would be better and fit my amp's power please please post. ha from reading around I've fallen in love with what I've heard about CDT.)
Username: Nd4spd18
Philadelphia, PA
Post Number: 11653
Far as i know all CDT component sets are 4 ohm final impedance to the amp. ES series their top line.
http://cdtgold.com/es62i_2.htm
That is similar to what i have with a newer model tweeter and crossover. Doesn't get a whole lot better than that unless you start spending super big $.
" What about Infinity kappa Perfect 6.1? opinion on thoose? "
Terrible tweeters, very harsh.
Username: The_image_dynamic
San Diego, California
Post Number: 5871
Here
Username: Noob101
Post Number: 217
Bought these..
http://www.woofersetc.com/p1103/CLE61CV-CDT-Audio-EuroFit-65%22-2Way-Component-S peakers.htm
Really happy with them so far thanks for the re assurance M.S. can't wait tell i get my Fi Q back from fi and have it all completely set up.
And thanks to everyone else who helped me decide (:
