Db-r sale
Username: Gcs8
Atlanta, Ga
Post Number: 1688
db-r is having a 25% off sale on all sundown amps until 1/1/2011.
http://www.db-r.com/sell/store/
Username: Cwruck
Post Number: 491
nice!! maybe ill get a 3000d, i wish they would have 2000s or 2500s tho. i havent seen a 2000d on there for months now, and i look maybe once or twice a week
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 16082
I almost bought an amp there good prices
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 201
Ha I guess I missed your thread when I posted my thread. I got my SAE1200 in the other day, and it is top-notch.
Username: Gcs8
Atlanta, Ga
Post Number: 1700
very nice.
Username: Joebruce
TC Sounds/DLS
Post Number: 3191
Nice prices on the SAE-1200s! Wish i had the money right now or I would snag one up. BTW whats the diff. between the SAE modles and the SAX or SAZ modles?
Username: Cwruck
Post Number: 500
sae models are best for just regular people not going crazy on a build.
the sae can't run over 15 volts or be used under 1 ohm. but if you dont have that high voltage, and can run subs at 1 ohm the sae-1200d v2 is actually better than an saz-1500d.. i know someone may want to argue this. but if someone had a regular 14 volt system and ran both amps at 1 ohm, the sae-1200d v2 would actually put out more power after impedience rise.
the sax 1200 really just seems like a waste of money to me, i think the sae-1200d v2 was maybe too expensive for them to make money off of, because seriously an sax-1200d can't compare to its older version
Post Number: 16113
i didnt like that the sae 1200d v2 only had 12 db per octave crossovers....only cheap amps have that
Username: Cwruck
Post Number: 501
ya thats true but the amp puts out beastly power!
Username: Gcs8
Atlanta, Ga
Post Number: 1701
The saz's are linkabule, don't think the sae is, sax maybe.
Post Number: 16114
the sae is not linkable
Username: Makinblak
Post Number: 203
^X^2
Username: Makinblak
Post Number: 204
x2 on the beastly power that is. how do i find out how many watts its pushing? can i use a dmm for that? And how to tell the final impedance?
Username: Joebruce
TC Sounds/DLS
Post Number: 3197
So would you all not recomend the sae models? Are they junk or just ok or what? Cuz they have a refurb sae-1200dv1 for $157.50 and it says it will do 1200wrms @ 1ohm. Now to me that sounds like a hell of a deal. They also have the sae-1200dv2 for $180-$187.50 which also claims 1200wrms @ 1ohm. Now what is the diff. in the sae v1 and v2s? Do they do rated power or no? Are they worth the money or should I look in to something else? I need around 1200wrms @ 1ohm so these amps seem like a steal. I was also considering the AQ 1200. Whats your opinions?
Username: Makinblak
Post Number: 224
I got the SAE dv2 1200. it has an improved heat-sink than the dv 1 thats the only difference. I think it is a helluva deal. this amp beats the balls off my truck.
Username: Gcs8
Atlanta, Ga
Post Number: 1716
i think that sae does ~1500 wats @1 ohm, iirc. its a great amp!
Username: Makinblak
Post Number: 225
x2
Post Number: 16153
the sae v1 had board issues
