Which subwoofer is the better the in sql
Username: Derrick417
which subwwofer sound better in sql the audioque hdc3 15 or dd3500 15
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 16041
the dd is better
Username: Sw9152
Michigan
Post Number: 884
They are both good subs and im sure you would be happy with either in a good install. If it were my decision i would go with the DD assuming you can get both at the same price. DD audio products are among the best available and have been for some time.
Username: Delsole
Post Number: 1756
I would think the aq would get louder but not by much and i think the dd would sound a lot better. DD= made in usa
Username: Livin_loud
MW2 Addict
Post Number: 3287
the 3500e has higher power handling and sensitivity than the hdc3. DD wins in all categories
Username: Gcs8
Atlanta, Ga
Post Number: 1657
i like FI's Q but thats just me.
i would say if you can get a good price on DD that would be my choice, there subs just look funkie to me.
Username: Jkidder
Worlds gunna end, In 2012
Post Number: 4273
LOL deathoob, the dd's and aq's are practically the same subs cosmetically. same basket, both have motor boots, same cone and surround... what makes the dd look funky?
Username: Gcs8
Atlanta, Ga
Post Number: 1661
mostly the dust cap. its like the subs nipp|e and i am pickie.
Username: Jkidder
Post Number: 4274
dj langford = owner of aq....
jassa langford = owner of dd
dj is jassa's father... if you didn't know
Username: Gcs8
Atlanta, Ga
Post Number: 1662
i did not but thats cool info to have.
i like both company's, just visual preference.
Username: Jkidder
Post Number: 4275
both dd and aq amps are built in south korea. the subs are all handcrafted in usa however.
Username: Gcs8
Atlanta, Ga
Post Number: 1663
sadly the amps would probably be ~200 more if they where built hear.
i don't know many amps that are US built.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 957
Arent Aq subs also built in China/Korea? I thought i remember someone on here saying that before.
If moneys not an issue i would go with the DD. Aq is hard to beat for the price tho...
Username: Jkidder
Post Number: 4276
ive heard someone say the aluminum coil is made in USA and the others are made in s. korea. but i've never been able to confirm that. imo it wouldn't make sense to differentiate between manufacture locations strictly because of coil option but idk...
Username: 04redmach1
Post Number: 2730
I will disagree. Not all of DD's subs are handcrafted in the USA anymore. AQ's aluminum coils are USA and copper is Korean. Of course most parts in a woofer are from China.
Post Number: 2731
By the way, out of those choices, the 3500 is what I would recommend.
Username: Cwruck
Post Number: 467
almost everything is made out of the us these days, to me it doesnt matter, if it works good and the cost is low ill buy it, instead of spending hundreds more for something that is all handbuilt in the us.
will a usa driver perform better? maybe, but if your only gaining 1 db using an american driver over a korean driver but spending 300 more for the us driver is it worth it?
not to me. i would rather build something that is cheaper and performs for what i want it to do.
i say the aq if price matters to you, the performance you would get out of the dd just isnt worth the extra money to me.
Post Number: 2732
Depends on the power and abuse you plan on giving the woofer. Chinese woofers are not bad if the company put the time and money into it and uses a good company. But when using a lot of power and abusing the woofer, you will want the american built more so the american coil.
Post Number: 16051
ive had both woofers the dd sounds best
