Stupid question
Username: Gcs8
Atlanta, Ga
Post Number: 1655
if i all ready deadened my trunk lid should i fill it with foam as well?
if so whats the best way?
/end of noob time.
Username: Glasswolf
Post Number: 14243
try not to use expanding foam unless you have to, and then only use it for places you can't reach with other forms of sound damping materials. If you used matting on the trunk lid, that should absorb resonance, and lower the sympathetic frequency of that piece of metal enough to be effective. If there is anything that's still ratting excessively that you feel needs attention, then you could consider the use of foam as needed.
Username: Gcs8
Atlanta, Ga
Post Number: 1656
good deal, was just thinking it might make the lid more ridged.
thanks as all ways glass, off to home depot for kitty proofing supply's.
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 187
get that 30 dollar 4-shelf and husky tool bag haha
Username: 04redmach1
Post Number: 2729
I would suggest using foam in your trunk lid. Do it in layers and not all at once or you will have an issue with body bulge. Not sure why you wouldn't want to use it. Lighter, works more efficient, and can get into spaces you can't.
Username: Tejcurrent
Post Number: 2617
Definitely take your time and do foam in layers. I did 15+ cans in my rear tailgate (tahoe) and it's like a rock now. Extremely solid, and by doing it in thin layers I got nice expansion without bowing my panels out.
Username: Streetlegal
Post Number: 11
Layers is the way to go, and remember there is no stupid question, only stupid answers...
