Could use so suggestions please
Username: Mpiro1993
New york USA
Ight so I have a 1999 Honda accord stock nd I'm lookin to upgrade my audio by addin subs etc. Um I was lookin at kicker l7s and type rs but wasn't sure. My budget is around $1000 so if n e one can give me some suggestions on a total system upgrade tht would be very helpfull thnks
Username: Mystre
Pemberville, Ohio USA
Post Number: 349
Okay, budget is good. Are you looking for SQ or SPL? How many watts are you looking to run? Stay away from Kickers if possible. There are better subs for about the same cost. Let us know these things and some of us will be able to help.
Username: Mpiro1993
New york USA
Well I'm lookin for a little if both of SQ and SPL I don't know how Many watts I guess ut depends on the subs but then again I'm really not that sure I am new to the audio stuff
Username: Loc_out
SoCal
Post Number: 3182
What all do you need? HU, component's amp's? Are you willing to buy used stuff?
Username: Mpiro1993
New york USA
Well I need a new HU and really just subs and an amp is wht I'm lookin for. If I was goin to get new speakers I would do tht later bc budget is sort of tight at the moment
Username: Loc_out
SoCal
Post Number: 3183
If you dont mind buying used. As far as a sub here is one http://www.caraudioclassifieds.org/forum/showthread.php?t=46463
amp
http://www.caraudioclassifieds.org/forum/showthread.php?t=49183
leaves you about 500 bucks left.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16514
a single ported low tuned 15" rated around 1000wrms shud fit in there & be plenty loud with good SQ too
check out ... : http://www.soundsolutionsaudio.com/store/brands/SoundSolutionsAudio.html
Username: Mpiro1993
New york USA
Now what about new subs any recomendations on those
Username: Kyle_lowe
Post Number: 1209
sure
Two Fi X 12" subwoofers with BP option (single 4 ohm voice coil) -- $280
https://ssl.perfora.net/www.ficaraudio.com/sess/utn154c58489f19b83/shopdata/0050 _Speakers/0045_X/product_overview.shopscript
One Audiodue AQ1200D Amplifier -- $250
http://www.audioque.com/aq/?page_id=26
This would be 870 wrms at 2 ohms to power the subwoofers
ALSO
DLS C6A - 6.5" 2-Way Component System -- $170
http://www.woofersetc.com/p7159/C6A--DLS-65"-2Way-Component-System.htm
Kicker 08ZX200.2 -- $100
http://www.sonicelectronix.com/item_11542_Kicker+08ZX200.2.html
that would be about $800 total
that should leave enough hopefully to get a amplifier kit, wire for the big 3 upgrade, and a box.
all of those are just suggestions. there are many other routes to go
Username: Mpiro1993
New york USA
um thanks but is Fi a good brand? i want the best bang for my buck, my dad always says cheap is exspensive in the end.... and i dont want these to not be worth it. I found a 15" mtx 9500 for a good price and either thinkin of that or 2 12" type-r's.Or a L7 but whts his name said kicker wasnt that great....i dont know
Username: Loc_out
SoCal
Post Number: 3186
FI, RE, DD, Audioque are better than type r's/L7. IMO.
Username: Mpiro1993
New york USA
ok wasnt sure there buddy thanks but wht about mtx are they better then that
Username: Loc_out
SoCal
Post Number: 3187
I'll pass on the MTX. I had a single 15" RE SE on my 94 accord. With a mmats 1600.2 amp and it was loud and clean. I was going to upgrade to a SX ported but sold my ride.
Username: Mpiro1993
New york USA
Post Number: 7
ight thnks. So now the thing is FI or RE bc u say RE is good and another said FI is also good....so what should i go for o plus i think i want a single big sub like a 15 or even 18 if i can get a big enough box to fit in my trunk
Username: Loc_out
SoCal
Post Number: 3189
Mike,
Here are some used RE SE 125 plus shipping. This will allow you to have more money for a nice set of comp.
http://www.caraudio.com/forum/car-audio-classifieds/485308-fs-two-re-se-15s-%241 25-plus-ship-ea-d4s.html
Username: Kyle_lowe
Post Number: 1210
Thats a great price on those SE's.
Very comparable to the Fi SSD (obviously). Maybe just a bit more on the SQ side IMO.
And an AQ 1200D would be great for one of those.
if you are looking for a mix of sq and spl, that RE SE at that price would be really hard to beat.
