What to use.
Username: Crayola0
Portage, Wisconsin
Post Number: 2648
im gunna building a ported box for my memphis its gunna be 2 cubes tuned to 35 hz but i have some questions. What glue should i use? What caulk or silicone should i use? Its in an integra hatch and should i do sub up port up? sub up port back, or sub back port back?
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 14370
sub up port back.....tite bond 2 wood glue
Username: Gcs8
Atlanta, Ga
Post Number: 645
^^^^^x2 also get a counter sync bit and some right angle clamps.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 23000
Titebond is good. The glue is important but not as important as getting the joints tight. Best glue in the world won't fix a sloppy joint. Clamp it tight and let the glue do its' job properly.
