Username: Perfectcircle IndyTC sounds 18...
Post Number: 64 Registered: Feb-10
Tuesday, June 22, 2010 - 01:40 GMT I've got an old soundstream 2 channel picasso 520 amp. Was going to put it in my wife's 330I but I'm going to go a little nicer with her car. Anyways, I bought a little honda civic beater car to commute in so I keep miles off my tahoe. Want to put a real budget 15 in the trunk. would have to be dual 2 or single 4. Anyone have any ideas. around a hundred or hundred and fifty. but cheaper would work. Just want to see how loud I can get a really low budget setup.
Username: Rosrock Michigan
Post Number: 378 Registered: Mar-09
Tuesday, June 22, 2010 - 02:03 GMT type r 15...
Post Number: 65 Registered: Feb-10
Tuesday, June 22, 2010 - 02:13 GMT I've owned a ton of subs over the years and I've never givin a type r a try. pretty decent sub for the money?
Post Number: 379 Registered: Mar-09
Tuesday, June 22, 2010 - 02:22 GMT o hell yea... ive heard 2 12's in a sealed box off a soundstream 700 watt amp (so maybe it was 500-600 true rms) in a blazer and it was loud enough for me hehe... but it just wasnt as CLEAN but that may of course be because lots of crap was rattling to as my idmax, tc9, and icon.
Username: Boston_spl Highland,
CA
United States
Post Number: 184 Registered: Nov-08
Tuesday, June 22, 2010 - 04:16 GMT AudioQ SDC2.515 ($159) or if you want to spend much less... Orion Cobalt CO154S ($69)
Post Number: 66 Registered: Feb-10
Tuesday, June 22, 2010 - 19:03 GMT Anybody else have a suggestion?
Username: Jbpitt Pittsburgh,
Pa.
Usa
Post Number: 454 Registered: Jul-09
Tuesday, June 22, 2010 - 19:19 GMT dd1515? Though im not to sure on the price. Or maybe a IA 187? there around $100 i believe
Pa.
Usa
Post Number: 455 Registered: Jul-09
Tuesday, June 22, 2010 - 19:21 GMT Nevermind,i think the 187 only comes in a dual4.
Username: Cwruck Post Number: 290 Registered: Feb-10
Tuesday, June 22, 2010 - 22:37 GMT that audioque sdc 15 will be like 180 or so shipped but well worth it, doesn't take much power to get loud. if thats too much maybe find it used on a forum, just don't know any other subs that would perform close to that for under 150
Username: Southernrebel Monroe,
Louisiana
Team Audible...
Post Number: 8106 Registered: Mar-04
Wednesday, June 23, 2010 - 01:14 GMT American Bass DX? Not a bad sub for the $. Pretty solid w/ around 500wrms...svc 4ohm also.
Username: Insearchofbass 2 hifonics 2607s,
2dcSounds12xls
SPL\idmax12SQ
Post Number: 14281 Registered: Jun-04
Wednesday, June 23, 2010 - 21:15 GMT x2
Post Number: 68 Registered: Feb-10
Thursday, June 24, 2010 - 13:52 GMT Thanks canaan! just ordered one for 58 bucks. always wanted to do a budget setup just to see how cheap and how loud I can get it. 58 for sub and 90 for the amp.
Username: Gcs8 Atlanta,
Ga
Post Number: 624 Registered: Sep-09
Thursday, June 24, 2010 - 14:02 GMT pic's and maybe a build log?
Post Number: 70 Registered: Feb-10
Thursday, June 24, 2010 - 14:07 GMT I was thinking about it. Just didn't know if anyone would be that interested in a cheap install like this.
Ga
Post Number: 625 Registered: Sep-09
Thursday, June 24, 2010 - 14:32 GMT an install is an install. and it would be neat so see what a budget setup can do.
Pa.
Usa
Post Number: 458 Registered: Jul-09
Thursday, June 24, 2010 - 20:03 GMT It doesnt matter,everybody loves pics! You cant beat that price on those Ab dx's. What amp did you get for it?
Post Number: 73 Registered: Feb-10
Friday, June 25, 2010 - 01:38 GMT Have an old soundstream picasso 520.2 just a budget install on a third car.
