I think i finally fig out what imma do
Username: Mittens08
Cleveland, Ohio USA
Post Number: 91
ok im gonna sell the 15xos and get a single fi q 18 dvc 1ohm and run that off that american bass sq880 in 1ohm for a lil i will buy a dif amp later on...box wise i will prob build a box for it...i did some measurments in the my trunk and it can work for a single 18 in prob a sealed box...or should i port? i already have a 120amp alt and new batt and have 4g wire.
Username: Cwruck
Post Number: 224
if u want to run at 1 ohm you need a single dvc 2 ohm Q. I think thats a great idea, im also in the process of finishing my box for my 18" Q which will be ran off a sundown sae-1200d.
I've heard great things about them in ported boxes with sq and they absolutely shine for sq in sealed, so ive heard.
I am doing ported just for the fact i want to be loud, but still have some sq
mine is going in the trunk of a 3 series bmw by the way so its def possible to make it work
Username: Mittens08
Cleveland, Ohio USA
Post Number: 92
ok ill order the dvc 2ohm but im gonna run it off the american bass in 1ohm for a lil so i can order the rims i want and do some window tint..but im thinking im gonna get a sundown 2000 later on
Username: Cwruck
Post Number: 231
a sundown 2000d is too much for that sub.. i would say the 1000d or 1200d
plus just to run a 2000d properly you would need to upgrade your electrical
