Need Help Choosing Sub Before SPL Comp.
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 580
Hey guys i havent been on here for a while now but i really need some help, i am helping a buddy throw a system together for our local spl comp on june 26th. currently he has a rockford bd1000a1 amp, its wired down to 1 ohm on a pioneer spl 12, but he is selling that sub, and he wants something that will hit a good score at the comp, the spl comp is just basic with 3 classes, goes by area of subs, so class 1 is 2 10's or 1 12, class 2 would be 2 12's or a 15, and class 3 is anything more then class 2. i am looking for a sub or a couple subs possibly for the class 1 or class 2 to hit around 140 db as i know people in class 3 only hit 144 or 145. btw its going in an 01 dodge dakota quad cab, so theres lots of room in the back, he is willing to spend anywhere from 200-400 possibly more on subs and box. i know theres alot of people on this forum thats great with this kind of stuff, so let me know,here are a couple subs i have found in my area.
1 15" Re Audio SX- $250
2 10" soundspliter RL-I 10" D4- 250$
Username: Deadrabit
Marionville, MO
Post Number: 2419
FI BL
AQ HDC3
DD 3500, or 2500
i would get on of those . i know for a fact the BLs get loud with 1k. and DDs also do! the audioque sub is just a great deal for the money.
if u want to get loud u need to build a box on ur own or have some one else do it for u. u will get louder if u have some one build a box... but if u really want to get loud u will need to find a TL mic and do some testing in ur car.
Username: Kyle_lowe
Post Number: 1138
what class is he competing in?
Username: Deadrabit
Marionville, MO
Post Number: 2420
idk. a single sub is what i guessed
Post Number: 581
either class 1 or class 2, i only have 1500 watts rms, so i dont want to enter class 3. and alright i can build a box if i have the dimensions. i built one for my power hx2 a few months ago. any other ideas boys? should i do 1 12" or 2 10"s or a 15"?
Post Number: 582
ok so i found that 15" Re SX, or for the same price i can get 2 12" re sx for the same price, remember i have approximatley 1200-1500 rms amp at 1 ohm, which ones should i grab?
Username: Kyle_lowe
Post Number: 1139
the 2 12" i would say
Post Number: 583
why? because i can either power the 15 to full potential or i could underpower both 12's by quite a bit?
Username: Kyle_lowe
Post Number: 1140
more cone area off of the same power should be able to get louder
Post Number: 584
can somebody help me design a box quickly for the 2 12's or the one 15 then?
Username: Deadrabit
Marionville, MO
Post Number: 2421
hey chris find me on fb. my name is luke kennedy. or my number is on the audioque website. if i have time i might draw u up a box
Post Number: 585
hey man i cant find you on facebook and i cant find your number on the website, shoot me a text 905 516 9546
Post Number: 586
alright guys i ended up picking up the two 12" re audio sx's for inside teh quad cab dakota, i need box plans, can somebody help me put shoot me an email chrismaskell1@gmail.com
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16369
why did u pick 2 sx which are rated 1000wrms each ... 1 wud have been fine off that amp
spl is a trial & error thing so i suggest 4" precision aeroports found on parts express - get 4 of them & some extra tubes lengths so u can experiment with to figure out what will give u the best numbers.....
Post Number: 588
i would just like to do ok in the comp i dont need an all spl box, i want something i can use daily, i want it to hit the lows good, and i want to avoid buying aeroports as i dont have a credit card to order them lol, so can i just make square ports or L ports or whatever their called?
Username: Rovin
Post Number: 16370
ok well then it wud be worth it to make a box with a removable port using T nuts & bolts so u have 1 port to be used for comps & 1 for daily since a daily tuned box wont do well for spl at all & a higher tuned spl box will sound shiddy for daily quality music ...
