Fuse in power line blows immediately
Username: Mj3223
as soon as i turn on my amp the inline fuse blows. It never use to do this before. How can i fix this
Username: Skdooley
Roanoke, VA Usa
Post Number: 305
Sounds like a wire is touching somewhere. Is there anyway the wires could have been rubbing somewhere along their way from the battery to the trunk and rubbed some cover off the power wire?
Username: Mj3223
i finally fixed the problem...it was a bad ground but as soon as i got the amp running the sub cut out after about 20 seconds. any advice?
Username: Blackdxblade
Post Number: 14
how many subs? I have had this problem before when the subs were wired at an ohm level that was unstable for the amp
