New member Username: Coltrain12345Illinois Post Number: 1 Registered: Feb-10 | I have three JL Audio 13W1v2-4. Are these even capable of putting all together? What amp would be good for this job (lets not get too pricey please) |
Gold Member Username: RideredderCornell, IL USA Post Number: 1772 Registered: Sep-05 | Three SVC 4 Ohm subs will give you a final impedance of 1.34 Ohms. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 5585 Registered: Dec-06 | ^^^^ And they want around 300-400RMS each so the AudioQue AQ1200D would be perfect for $249 shipped. http://www.audioque.com/aq/?page_id=26 |
New member Username: Coltrain12345Illinois Post Number: 2 Registered: Feb-10 | these subs only go to 2 ohms soo that wont work right? |
Gold Member Username: BonhamdTraverse City, MI Post Number: 2047 Registered: Nov-07 | http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=41 you would want to wire like option 1 |
Platinum Member Username: James1115Use a simple... Post Number: 10740 Registered: Dec-04 | no cole when you wire them parallel you get a final impedence of 1.34(in a perfect world) and we don't live in a perfect world so figure each vc at about 3.6-3.8ohms each now when wired down your total resistence should be right around the 1ohm mark. any amp that does 1200 @ 1 ohm should suffice. |
Silver Member Username: PoprocksPost Number: 300 Registered: Mar-09 | Phoenix Gold X1200.1(1200x1 a 1-4ohm) |
Platinum Member Username: James1115Use a simple... Post Number: 10745 Registered: Dec-04 | there you go! in your situation a regulated power supply would prob be the way to go |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2954 Registered: May-07 | ^been a while since I heard someone recommend that amp lol. Not trashing the amp as I have only heard good things about them. |
