Quick Simple question
Username: Mauskar
I have 1 alpine type R 1242D DVC. I believe the sub is rated at 500 RMS (250 each VC). If the VC is 4ohms, can it only be wired for a 4 ohm load? I was looking at the Alpine MRP-M650 or Alpine MRP-M500 to power this- is this enough???
Username: Insearchofbass
York, Pennsylvania
Post Number: 13294
a single dual 4 can be wired to 2 ohms or 8 ohms an alpine m500 is enough
Username: Mauskar
So just to make sure i understand this, the impedance on the sub doesnt really matter as long as the amp can handle the impedance....
A DVC 4ohm sub can be wired to an amp @ 2ohms???
thanks
York, Pennsylvania
Post Number: 13295
it matters if your trying to get the most power from the amp.....like if the alpine amp puts out 500 watts at 2 ohms thats what you want....yes a single dual 4 ohm can be wired 2 ohms or 8 ohms
Username: Mauskar
Yea, Im trying to get 500x1 @ 2 ohms. Is it possible to accomplish that with this 4 ohm sub?
York, Pennsylvania
Post Number: 13301
with a dual 4 ohm sub which you have yes
Username: Carpetking
i have jl 1000/1 can i hook it up to 4 subs or do i need a four ch amp ?
Username: Ford_toyota
Post Number: 12
Have you solved the problem now?
http://www.turbochargerpros.com/jaguar_supercharger.html
Jaguar SuperCharger
