Bronze Member Username: CalawayAustin, TX Post Number: 17 Registered: May-04 | Two RF Punch 8 inch RFD2208 HX2 subs. Dual 4 ohm coils 400RMS each. I know a JBL 600.1 would, but what other options are there? Mid to cheap side. |
Bronze Member Username: Chris_ballerPenetanguishene, Ontario Canada Post Number: 20 Registered: Jun-04 | the RF punch 1002 amp should work. its fairly cheap but its a mono amp if thats all you need. |
Bronze Member Username: CalawayAustin, TX Post Number: 18 Registered: May-04 | I can't seem to find that amp, what are specs on it? |
Bronze Member Username: CalawayAustin, TX Post Number: 19 Registered: May-04 | Basically, what am I needing from an amp to push them, what ohms/watt/chan config am I looking for?? Thanks |
Bronze Member Username: CalawayAustin, TX Post Number: 20 Registered: May-04 | In a bit of a time crunch, please help |
New member Username: TwistaLawton, Oklahoma Post Number: 5 Registered: Jun-04 | buy a JL 500somthimg it will deffinetly give you what you are looking for for about 400 depending on where you look and buy it but that is what i have on 2 15s and it beets the piss out of them and the 15s are 1600 watts so as you can see it should work very good |
Bronze Member Username: Motoman22Dallas, Texas USA Post Number: 89 Registered: Dec-03 | http://www.justamps.com/Amp_Pages/Ultra_Linear/UL_classa.htm Not bad, 400w for $78 ... but not as good as a JBL either. Buy local if you can, warranty service over the internet is a joke. |
Bronze Member Username: CalawayAustin, TX Post Number: 26 Registered: May-04 | Which of those Linears should I be looking at Michael? |
Bronze Member Username: Motoman22Dallas, Texas USA Post Number: 91 Registered: Dec-03 | None of them but... Since you were looking for a budget-sensitive choice, whatever you can afford. Ultra Linear isn't at all a terrible amp, I'd use one over an Audiobahn any day. The big thing you have to watch out for in a lesser quality amp is installation sensitivity. You almost can't break a high-end Alpine, hook the power and ground up backwards..it knows better. The lesser amps don't have such protection circuits, one goof and it's toast. I'd really suggest a used high-quality amp over a new lower-quality amp. Ebay is full of them, research repair prices (most are flat-rate) before you buy and assume the worst. Figure a couple of weeks turnaround on the repair and enjoy your internally new, high-quality amp. |
