KeithK Unregistered guest | Anyone know of a pretty good quality amp that will put out around 80x4 rms that is fairly thin (about2" max) and about 10" x 8" the other directions? It needs to fit under the front passenger seat of an Xterra (I know I could do my homework but I thought if someone knew about one offhand it would save me hours of searching) |
Silver Member Username: Pat_lTucson, AZ USA Post Number: 301 Registered: Apr-04 | Try some older Rockford AMPs, there pretty small. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39744&item=5706223908&rd= 1 |
Bronze Member Username: Motoman22Dallas, Texas USA Post Number: 93 Registered: Dec-03 | 2"x10"x8" is enough room for most amps. Just find one you like, chances are that it will fit. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3504 Registered: Dec-03 | look at dimensions for a Kicker KX600.4 |
