Which way should port face?
Username: Mikiedoo
Post Number: 10
Hey guys i have a 2001 Lexus is300 with one 15"BTL in the trunk. I had fisher customs design me a box to fit and it is 3.5 cubic feet. I have my amps at the very back of the trunk and the box sitting in front of the amps. Right now i have the port faced toward the trunk of the car. It sounds good but i didnt know what would happen if i turned it around. I was wondering if it would be louder, clearer ect. If you guys could help that would be great.
Thanks,
Michael
Username: Bonhamd
Traverse City, MI
Post Number: 1638
just try it out - turn it around and see which way you like it best
Username: Big_edge_head
Milwaukee, WI
Post Number: 3235
Just experiment with different ways.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 2144
usually port back works best, but try to see what sounds best to you.
Username: Mikiedoo
Post Number: 11
thanks guys i will have to experiment.
Username: Mrskullz1
Brooklyn, New York
Post Number: 972
btw..sweet ride and sweet sub...wht amp u using?
Username: Mikiedoo
Post Number: 12
got two hifonic 1606 hooked up to each voice coil right now. i have the dvc one ohm, i am lookin to get a recone and do the dvc 2ohm so i can run it at one ohm. Want to go with a RD 3250. what do you think, or do you know of any good amps that run at .5 ohms. thanks bud.
Username: Th3pwn3r
I compensate...
Post Number: 9141
Yo Skullz, https://www.ecoustics.com/electronics/forum/car-audio/539758.html
