Noob needs help
Username: Loc_out
Team RE XXX
Post Number: 2578
I've notice I desperately need a second battery. I currently have a 300/180 HO Alt and a yellow top. Which of the below batter should i go with?
1. 0dyssey PC2150 $200
2. Yellow top $200
3. kinetic 2000 $240
Username: Deadrabit
Post Number: 915
odyssey or kinetic
not yellow top
i would prolly do odyssey. i have been told they are better
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 1056
i would take the odyssey over the kinetic anyday...i currently have a 2150 and its a beast
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2368
Not exactly. Odyssey does have good batteries, and so does the other 5 companies that use the same battery. Kinetic makes some great batteries, but I would look into Power Master.
Power Master D2400 (best battery for the price range)
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PWM%2DD2400&N=700 +400345+4294769489+115&autoview=sku
Username: Loc_out
Team RE XXX
Post Number: 2580
Anyone else????
thank you guys for your replies.
Diamond Member
Post Number: 22581
how about duralast from autozone?
Username: Redliner
Wilmington, Ma
Post Number: 4535
i like kinetic a little pricy but there worth it. Also nick makes a good point about powermaster.
Username: Loc_out
Team RE XXX
Post Number: 2581
"duralast from autozone"
Tell me more about than Chad???
Diamond Member
Post Number: 22582
you know me man. i am a autozone and sears kinda guy.
Username: Redliner
Wilmington, Ma
Post Number: 4540
A lot of people have used duralast here for under the hood. There cheap and put out a lot of power.
Username: Snowball123
West Allis, WI
Post Number: 1403
built to last, duralast.
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14253
there r fans of each brand on here & each is good - in my ride i use the bigger D31 yellowtop ....
Username: B3n07
Louisville, Ky USA
Post Number: 968
what about Alpha Cell batteries
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2856
I'll be getting a yellow top for my next battery. One reason is I know someone with a yellow top and it preforms great. Another reason is because I like how they include both side posts for GM's and the regular posts. Makes life simple:-)
West Allis, WI
Post Number: 1404
cause life is so rough for you.
Post Number: 2857
LOL. You're dumb.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8618
Odyssey all the way..... but whatever you get replace the yellow top so you're not mixing batteries.
Ether the odyssey or kenitik will absolutely destroy the yellow top though. Optimas the yellow in particular are to put it bluntly a pile of crap in comparsion.
" I'll be getting a yellow top for my next battery. "
You have fun with that..... a similat size odyssey or kenetik will own that battery, plain and simple.
Post Number: 2860
Upload ok M.S.
Diamond Member
Post Number: 22583
odyssey and alpine ftw b!tches!!!!
Username: Loc_out
Team RE XXX
Post Number: 2583
Okay it looks like i'm going to get the Odyssy battery.
Username: Deadrabit
Post Number: 920
X2
Username: The_image_dynamic
San Diego, California
Post Number: 4620
Fast forward three days...
quote:
stinger and eclipse ftw b!tches!!!!
West Allis, WI
Post Number: 1411
hey lowlife, where did you find the PC2150 for $200?
Username: Loc_out
Team RE XXX
Post Number: 2586
Some local guy is selling his.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8627
Stinger batteries are the same as odyssey sold under a different brand name.... and they jack up the price.
Username: Tatonka
Post Number: 2369
Power master is still the best mentioned. lol
If you're going to get an odyssey, look into the other 5 brands that carry the same battery to see if you can get it any cheaper.
West Allis, WI
Post Number: 1413
What would those brands be Nick V.? And do you know of a site that has good prices on Power masters?
Username: Loudon
Post Number: 2775
ive ran a yellowtop for 5 years now
no problems whatsoever...
Username: Trueaudiophile
New York
Post Number: 36
i would look in to some lifeline batteries. they are the best imo.
Username: Loc_out
Team RE XXX
Post Number: 2587
Funny thing is i hear of those batteries this weekend. You got a link to those lifeline???
New York
Post Number: 39
http://www.lifelinebatteries.com/
let me warn you though. they are a bit pricey. but worth every penny imo.
Username: Tatonka
Post Number: 2370
Stinger, Hawker, Enersys, tsunami
Summitracing deals power master.
Username: Livin_loud
Post Number: 2672
the lifeline GPL-8DL is monstrous. 162 lbs, 1975 cca @ 68*...
Username: Bernymac
Phnom PenhCambodia
Post Number: 4375
You know me Gus, Odyssey ftw.
Username: Loc_out
Team RE XXX
Post Number: 2588
Thank you guys for all of your advice. At this time i'm going to pick up the Odyssey. i'll keep my eyes on those Lifeline they seem a little to big.
Username: Loc_out
Team RE XXX
Post Number: 2590
True Audiophile which lifeline would = the Odyssey?
New York
Post Number: 45
what do you mean by which lifelin = odyssey. that is such a vague question.
Username: Basebalz13
Moneta, Va Usa
Post Number: 703
powermasters
Username: Loc_out
Team RE XXX
Post Number: 2604
Quick update. I picked up the 0dyssey PC2150 over the weekend. Installed it so far I feel like i made the right choice. No more lights diming. Thank you guys for the help.
West Allis, WI
Post Number: 1484
sweet. looks like my next battery is going to be odyssey.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8717
You put that under the hood or in the back? Thats a beast of a battery.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8718
Optima yellow top: 900 amps
Odyssey 2150: 1500 amps
Aren't you glad you researched that one eh.
Username: Loc_out
Team RE XXX
Post Number: 2605
yellow top 900 amps on the front. Odyssey 1500 amps on the back
Username: Th3pwn3r
I compensate...
Post Number: 8824
If you're looking to get the best battery for your dollar don't go with the Odyssey. If money isn't an issue then by all means run it.
West Allis, WI
Post Number: 1488
what's best for your dollar than almighty rob?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8724
Yeah, do tell us what is better for $200
