Fi Q vs Treo SSI vs RE SE 15" in 1.8cuft sealed
Username: Dan_white
Post Number: 62
Can't find any Si Mags and Treo hasn't emailed me about any dealers who sell 15". I know I've posted a few threads but I'm narrowing it down.
With my sealed box I'll have around 1.75-2cuft to work with...most likely around 1.75. That being said, I like the Fi Q a lot seeing as it takes 1000 watts but it recommends at least 2cuft of space.
My box is as much room as I have. I'd appreciate any insight.
Username: Semperfi
Post Number: 9
is that a prefab or is i custom built? if prefab plz remake and have a pro do it, it will be worth it
Username: Dan_white
Post Number: 63
i built it. thats why i want to use it.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8688
It think the Q would work. With a sealed box it can be a little off from spec and not have a problem.
Username: Dan_white
Post Number: 64
really now? It recommends 2-2.6. I really dont want my low end to suffer, but then again couldn't i use a little polyfill or something?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8691
Yep you could try that
Username: Dan_white
Post Number: 65
ive heard polyfill can act as an addition of up to .5cuft. True?
Username: Dan_white
Post Number: 66
