Rockford T212D2 - questions on using this sub to replace a blown one
Username: Esprit
I had a setup using a 12" Audiobahn 1208Q subwoofer. Now I know Audiobahn subs are garbage, I made the mistake of buying one to save money.
It blew. It was rated at 1500rms. So I bought a 1200watt monoblock amp to power it (Audioque 1200).
Now I want to replace it with a Rockford T212D2 and run it at 1ohm so I get the most power out of my amp.
Any suggestions? other subs I should go with? My box was built for the 12\" Audiobahn. Is the rockford going to sound bad if I dont change the box? Help me out!
Username: Ctmike
Ct.
Post Number: 6502
it would help if you posted the specs of the box. and i wouldn't buy the rf personally, i'd look into another sub. what's your budget?
Username: Somedonniedude
Illinois United States
Post Number: 1989
Box specs?
Username: Esprit
Post Number: 7
The box I have was built to these specs:
Air Space Cubic Feet 2.3
Port Size (Inches) 4 x 7.25
Port Vel. (%) 22.61
-3dB (Hz) 32.5
Tune Freq. (Hz) 38
Sub Disp. (Cu. Ft.) 0.27
Port Disp.(Cu. Ft.) 0.047
Total Vol. (Cu. Ft.) 2.5
The rockford is $600CDN
Im willing to spend that much on one 12" sub.
But I need a sub that can be wired to 1ohm. My amp is here:
http://www.audioque.com/aq/AQamps.htm
Username: Cozce
Post Number: 233
You can find A LOT of much better subs out there for $600. Are you going for SQ, SQL, or SPL?
Username: Esprit
Post Number: 10
I will sacrifice sound quality for loud bass
That said, I dont go in competitions or anything.
So any suggestions?
Username: Mj23dynasty
Alpine ida-x001/2 dd 2..., Woodlawn Por... USA
Post Number: 1965
although i have heard this sub at a local shop and like it alot it is defintely not worth 600 for 1 12" sub thats prolly msrp. bcuz my high priced local store was only selling it for 400 and their prices are redicuulous on alot of stuff.
Username: Brewsky
Prince george, British colu... Canada
Post Number: 105
i would say go with a 15" if u have room with a new box
FI BL 15"
it would pound on 1200w rms from your amp and the sub would prob set u back only 350
Username: Deadrabit
Post Number: 765
i would love to have a fi Q that would be great! if ur want sql
look at the fi BL, AQ hdc3 with copper coils
re sx
good subs
building ur own box is always best. i can help with a design if u want
Username: Snowball123
West Allis, WI United States
Post Number: 1072
i wouldnt trust him though.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2657
x2
Username: Brewsky
Post Number: 107
x3 ...i could get u a good design if u wanted :D
Post Number: 1085
wouldn't trust you either.
